Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-20-2007, 02:20 PM
Darrick147's Avatar
Darrick147 Darrick147 is offline
Send a message via AIM to Darrick147 Send a message via Yahoo to Darrick147
What would you do with $600?
If you had a stock 2g Eclipse GST and had $600 to spend on it and get it to about 250-260hp what would you do?
Old 11-20-2007, 02:43 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Re: What would you do with $600?
New turbo...duh! lol
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 11-20-2007, 02:48 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Don't assume thats the best thing to do... First off, a new turbo is going to more than go over his 600 dollar limit... Also, the T25 just might have enough balls to barely get that 250hp goal... I would let it breath better with an open element intake and a 3" exhaust turbo-back... Add a manual boost controller, an AFC, and some 550cc injectors... With those mods you will probably be at your 600 dollar mark and it should put you up to around 230ish hp with a good tune running a bit more boost... Next you would want to look into upgrading your turbo and adding a front mount intercooler and some aftermarket intercooler lines...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-20-2007, 03:54 PM
I stand corrected, i wasnt thinking about the intercooler.
Under The Hood:
Interior:
Old 11-21-2007, 12:59 AM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Yeah the first things you will want to do will be let it breath better. So an intake and exhaust would be the best first things to do.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 11-21-2007, 01:26 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
First off, you should not look at $600 and expect it to achieve your goal. It will help, but will not get you to 250 whp by any means. Brian's list is pretty good, but new value on all that is over a grand. You will need to shop around and shop around hard to do it for $600.
Thor's first $600:
-3" turbo back exhaust: $350-$500.
-K&N filter: $50
-1g bov: $30
-JoeP MBC: $40
-Boost guage: $50.
That should get you started, but like I said, dont expect 250 whp. As stated, you'll have to shell out for SAFC, probably injectors, a fuel pump rewire, and decent intercooling before you can get that kind of power, plus I dont think that T25 can support that much power.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-21-2007, 08:56 AM
It can support around 250-260ish max...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-23-2007, 11:06 PM
kittay's Avatar
kittay kittay is offline
First, I would make sure the car can hold any mods (maintenance). Then fuel (fuel pump/ injectors), then intercooler.. support then the goodies.
I mean on my car, I'm at 350 and spent around 1k for all my mods... but I also know where to find good deals/ trades, etc.
12.3 @ 112
12.5 @ 115
