Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-20-2007, 12:00 PM
Beggs Beggs is offline
No headlights - 2003 CV
the headlights on my CV won't turn on. Everything else;turn signals, parking lights, brake lights, etc works fine, but when I turn the switch on for the lights --- nothing. I've already replaced the light switch, but that didn't do the trick. Someone said the relay may be bad (?). Could it be a fuse? Appreciate some assistance.
(the high beams work but only when I pull back the turn signal arm)
Old 11-26-2007, 01:12 AM
03_panther 03_panther is offline
Re: No headlights - 2003 CV
I have kinda the same problem. I'll be drivin down the road and after about 10 or 20 minutes the damn things just shut off. They work when you pull the turn signal arm back but other than that, nothing. Bout 30 seconds later they pop back on. I've tried wiggling wires where the headlight flasher was and everywhere else. Can't figure it out. Good thing I still got the spot on the A- pillar I guess.
Old 12-02-2007, 06:33 PM
Thanks 03 Panther... ended up taking it to the dealership. We'll see what they come up with!
Old 12-04-2007, 08:29 PM
I talked to a guy that works on the cars for a city agency and he said it could be a circut breaker.
Old 12-05-2007, 02:27 AM
Davescort97 Davescort97 is offline
Escort guy
Could be the headlamp relay is overheating and shutting them down. Then, after it cools down some they will come back on. That or the circuit breaker if it has one. That's got to be a PITA for night driving.
Old 12-06-2007, 09:15 AM
It's not the circut beaker cause I yanked it out while driving down my road lastnight. Didn't do anything to the head lights. When they go out I can whack my LCM and they come back on.
Old 12-06-2007, 07:53 PM
fleettech fleettech is offline
found your problem and for the low low price of about 4-500 dollars it will be fixed.
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 12-07-2007, 12:05 PM
I was afraid of that.
Old 02-21-2009, 12:39 PM
sonny kemp sonny kemp is offline
what is your "lcm ?" how do I wack mine ?
Old 02-21-2009, 06:44 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
LCM is lighting control module. It is located above your right foot up under the dash.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-22-2009, 02:52 PM
Yeah as way2old said it is above your right shin. I could always give mine a swift bump with the palm of my hand and the lights would come back on for a little while. Eventually replaced my LCM. Gonna cost you about $500 from the dealer. Might see if you could get one from a junk yard.
Old 09-27-2009, 10:16 PM
agent8698 agent8698 is offline
I have the same problem on a 2003 P71: headlights will turn off by themselves, then come back on a few minutes later, then turn off again etc.
Apparently, this is a known problem with the LCM (lighting control module), and it involves one particlular relay: the headlight relay, on the LCM. I learned about this on crownvic.net:
http://www.crownvic.net/ubbthreads/u...02#Post1437302
So you can either replace the headlight relay (apparently involving un-soldering of the bad relay, as explained in the post), or you can remove your LCM and mail it to this guy:
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
who will repair it for you for a $45.00 fee with free return shipping.
Or, you could go to a dealer and pay hundreds of dollars ($400 or $500 or more from what I've read).
I don't know what I'm going to do yet, depends on whether somebody I know is able to do the unsoldering and the external wiring (external to the LCM board). I think I'll find out tomorrow. The relay itself can be purchased online including shipping for less than $15. I think it can also be purchased at auto parts stores for a similar price. But there is a warning in the crownvic.net post: "I DON’T RECOMMEND DOING THIS UNLESS YOU KNOW WHAT YOURE DOING." So I might end up paying the $45 to the eBay guy, as well as shipping the LCM to him, which might be another $5-$10, so my total cost for the repair will be $50 to $55.
Old 09-28-2009, 03:44 AM
I replaced mine. I got lucky tho. We had a wrecked 05 CVPI so I just got that one.
