Old 11-19-2007, 11:15 PM
Dipasqua002 Dipasqua002 is offline
2003 Grand Am - Loss of Power
I was driving and came to a stop. I started going again to only have the car stop moving. All the power was still on in the car, however I could not get the car to move. When I stepped on the gas pedal the engine reved, but would not go. I turned the car off, and back on after about a minute and power was restored. Anyone else have similar problems?
Old 11-22-2007, 10:58 AM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 2003 Grand Am - Loss of Power
Sounds like it's a transmission issue. Check the fluid level and condition. If both are good, you may need a re-build.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
