Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 11-19-2007, 08:57 PM
Livonia Livonia is offline
2003 Rendezvous Growling noise
I've taken my 2003 Rendezvous CXL AWD with 57,500 miles to the Buick dealer and he couldn't help. Hope someone out there can. I get an intermittent growling noise which occurs when the car is at steady rate of speed and the transmission drops down into over-drive (tachometer reads 1100 to 1400 RPMs). The noise is the loudest or most obvious when the engine is warmed up a little and the car is traveling at 30 to 40 MPH. It's driving me nuts. It's not the front hub bearings, I had those replaced at 45, 000.
Old 12-15-2007, 09:03 AM
Carwhiz Carwhiz is offline
Re: 2003 Rendezvous Growling noise
take back to your dealer....the growling noise is due to weak quality fluid in the rear differential. there is a bulletin your dealer should follow for this complaint. basically you need to confirm the noise is coming from your rear end, and if so, simply replace fluid. I would recommend replacing fluid anyways. use veratrak, available from your dealer. Again, there is a bulletin on this complaint where you local Buick dealer should be well aware of this complaint. I know we are.
