Old 11-19-2007, 08:03 PM
sshallenburg sshallenburg is offline
97 Grand Am jerking while driving
3 weeks ago accelerated to get around semi, car began to run rough. Then jerking movement when accelerating. Changed coil packwhich was damaged,spark plug boots, spark plugs, fuel filter. Car still jerks and misses when driving RPM's around 2000 and accelerating, also jerks and can see the miss in the RPM gage when stopped at a light or in traffic. Trouble accelerating and going up a hill. What else could it be??????? Please help, do not want to get rid of car, but if I can not get it fixed will have no choice.
Old 11-19-2007, 10:24 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: 97 Grand Am jerking while driving
Did you test/check the ICM ?
When was the last time the fuel filter was changed ?
and welcome to AF.
1999 Grand Am SS 3.4 OHV
Old 11-20-2007, 07:56 AM
the fuel filter was just changed on Friday, could it be the feul regulator or perhaps the throttle body needs change could some one please let me know
Old 11-21-2007, 08:50 AM
It is possible you fuel regulator is bad, get your fuel pressure checked.
Kinda sounds more like ignition components then your throtle body.
Though it could be your TPS or IAC on the TB, might test those and see if they are functioning properly.
This link has test procedures for those two components.
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Hope that helps.
