Old 11-19-2007, 06:23 PM
blu3kgt blu3kgt is offline
Iac
ok well my cel came on and it's shooting code p505 which means there is a malfunction in the idle control system... so how am i able to determine if the IAC motor has gone bad itself because my car doesn't idle all crazy like i have read in previous situations, but what my car does do is when i cold start, it will rev to like 2000 rpms and then slowly come down to regular idle....but what i have come to realize is that if my car will be idleing for example at 800 rpms, if i turn the car off and start it, it will give me a different idle reading each time i turn the car on and off, .... so is it the IAC motor?? i have read the faqs but i just want an opinion
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 11-19-2007, 07:41 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Iac
Hmm, thats a tough one, usually the IAc makes the idle very eraticly, Id almost say wait it out a little and see if another symptom arises. maybye clear the codes and see if it pops again.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 11-19-2007, 10:28 PM
mistermoonpie mistermoonpie is offline
Re: Iac
Did your CEL come on because you gutted your precats? If so, you sure made quick work of them! If not, disregard this reply
'97 3000GT SL
-Short Ram Intake
-Test Pipe
-Custom Exhaust
-17" Infinity Rims
-Infinity Kappa Component Sound System
-Kenwood Double Din Headunit
Old 11-19-2007, 10:31 PM
sLADe781 sLADe781 is offline
Re: Iac
Pull it and test it: http://www.stealth316.com/2-isc-iac.htm
Old 11-20-2007, 01:13 PM
Re: Iac
ok well i tested it and on the link it says for the original IAC the ohms reading should be between 28-33 ohms and for the newer models it should read 40ohms.... and the readings i got were 37ohms from all the terminals and mine is the original, which means its abnormal.... so now my question is, what does that mean??? does it mean i need to clean my IAC or does that mean the motor is bad and needs to be replaced??
Old 11-21-2007, 01:42 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: Iac
Those specifications for the IAC have been proven to be not accurate. When mine was bad, everything tested perectly within spec., replaced it and problem was solved. You could try taking it apart and spraying it down with electronics cleaner, sometimes helps. If it doesn't, find a good working one and swap it in. If it doesn't solve the problem, you can always just sell it to someone else who needs it.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
