Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-19-2007, 06:16 PM
Robert Moller Robert Moller is offline
fuel pump power again!
95 rodeo....ok, only 9.5 volts at fuel pump with a new battery and a new fuel pump, fuel filter..........i have 12 volts at fuse, but only 9.5 at pump???? i dont know what to do next!!! any help would be great! Thanks for your time.
Robert Moller
Old 11-19-2007, 07:16 PM
2000izusu 2000izusu is offline
Re: fuel pump power again!
your fuel pump relay may only be letting 9.5 volts through due to years of snapping closed and open (cauing scored contacts)! this can especially happen when the brushes in the old fuel pump wear and need more amps to run the pump! pull the relay out, jumper the terminals and then see what the voltage is! mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 11-19-2007, 09:28 PM
i have swapped all the relays checking them with the horn, im not sure how to jumper the relay??? is the relay b4 the fuse, because it read 12volts at the fuse....
Robert Moller
Old 11-20-2007, 12:17 AM
trooperbc's Avatar
trooperbc trooperbc is offline
make it easy on yourself.
just swap the relay with another in the box that is the same.
if all works, relay is your problem.
if that doesn't fix things, then keep checking.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
