Old 11-19-2007, 11:24 AM
rustyabiding rustyabiding is offline
High Idle Problem
I have a 1989 Jeep Cherokee and latley it has been idleing at around 2000 and i know it should be way lower. When it is really cold out it will idle between 1000 and 1500. I was thinking it had to do with the choke maby its stuck or something or maby im totally wrong. What should i do? Is there some way to check the choke? or is there something else wrong with it?
RustyAbiding
Old 11-19-2007, 05:54 PM
wwwildman wwwildman is offline
Re: High Idle Problem
I would check the IAC or TPS sensors on the throttle body. It also wouldn't hurt to check the fuel pressure at the fuel rail.
Old 11-19-2007, 07:18 PM
Ok thanks ill try that and get back to ya to see if it works out
RustyAbiding
Old 11-25-2007, 05:26 PM
Yep it was the MAP sensor thanks again
RustyAbiding
