Old 11-19-2007, 08:34 AM
homerun homerun is offline
99 Taurus with no heat
My 99 Taurus is blowing no heat. The car is not overheating and the AC works fine, and there are not anitfreze smells coming thru the vents. I have flushed the heater core and have moderate flow thru it. I have replaced the water pump. Any suggestions on where to go from here.
Old 11-19-2007, 05:05 PM
wafrederick wafrederick is offline
Banned
Re: 99 Taurus with no heat
Go to your nearest auto parts store and get two 90 degree 3/4" or 5/8" heater hoses,there is a metal hose coupling goes into he heater core under the hood that the 90 degree heater hoses replaceyou cut and reverse the heater hoses by putting the bottom one into the top one and the top one into the bottom one.This is the fix by cleaning the heater core.
Old 11-21-2007, 11:39 AM
I flushed the heater core once. How will back flushing the heater core fix the porblem?
Old 11-21-2007, 07:18 PM
mwt47's Avatar
mwt47 mwt47 is offline
Grab each of the hoses going into the heater core.
If one is hot and one is a lot cooler your heater core is plugged.
No need to buy any hoses just unplug them both and flush them.
If the Blend doors are stuck you won't get any heat either.
open the Degasser tank and see if you have the brown coolant issues.
Mike
