Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 11-18-2007, 10:22 PM
rscamaroboy89 rscamaroboy89 is offline
transmission question
how can you tell if you have a munsie 4 speed? is there somewhere to run the numbers? my dad has one from a 396 chevelle he thinks,but wants to make sure.
my car 1998 grand prix gtp,borla catback exhaust,fwi,u-bend delete,resonator delete,
180 t-stat,zzp 1.0 pcm,zzp poly motor mounts,zzp shift kit,3 inch high flow cat,3 inch cutout.
not installed:zzp 3.4 mps,autolite 104's
next to order:headers with 3" downpipe
Old 11-19-2007, 05:50 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: transmission question
http://www.5speeds.com/muncie2.htm
This should help. I've used it to ID a couple of cases that I had.
Bob
Old 11-19-2007, 01:10 PM
it must not be,cause the numbers are 3925656,the first few are right but not the whole thing. i found that it may be a saginaw 4 speed.
Old 11-19-2007, 02:12 PM
bobss396's Avatar
http://www.nastyz28.com/chevy-manual...tification.php
http://www.drivetrain.com/saginaw3_4sp.html
Check these links, which should get you started. There's others if you want to de-code the whole works. Saginaws are ok for street usage, but for day to day beating on or use with a high HP motor, you're better off with the Muncie or T10. Make sure you KNOW what you have there. Loads of Vegas and other later compacts came with them in the 1970's.
Bob
Old 11-21-2007, 12:58 PM
thanks for those sites. now i definantly know its a saginaw 4 speed.
