Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-18-2007, 08:02 PM
Nalayah Nalayah is offline
Timing Chain, Headgasket, '80 Caprice "H"
Ok, soon I will be picking my 1980 Caprice Classic (engine style is "H", V8 5.0L with a 4 barrel carb). I originally took it in many moons ago (yea, I'm slow at getting stuff done) after it just suddenly stopped starting (drove to the bank, got back in and turned the key...); it just turns over and over, with an occasional backfire (burst of fuel/air back out the carb). The mechanic that looked at it said that it might be the timing chain, as the rotor just goes around and stops, but he's seen similar stuff happen with camshafts.
Wouldn't this be a sprocket issue? If the timing chain were busted, I would have thought that it would just plain stop turning over, and figured that a sprocket is worn out or broken.
Also, the right side (driver's side, or left when sitting in the car) is spitting oil out. When I did the plugs back in April, one of them was covered in oil. Would this just be a headgasket? How hard would it be to replace it?
Thanks!
Old 11-18-2007, 08:15 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Timing Chain, Headgasket, '80 Caprice "H"
Oil - not a head gasket, but a valve cover gasket.
The suspect is the timing set - the cam sprocket was actually aluminum with nylon teeth, over the years this nylon cracks and falls off and then it's curtains for the sprocket. That's likely what happened with your engine.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-18-2007, 08:23 PM
Thanks! So should I order an entire gear set, or just one for the cam? Also, while I've got it off, should I replace the timing chain as well? And with the valve cover gasket, should I go for cork or rubber?
Thanks again!
Old 11-18-2007, 08:37 PM
silicon212's Avatar
Confoundingly Lucid
Replace the timing set as an entire set. Cam and crank sprockets as well as timing chain. I use "The Right Stuff" by Permatex for valve covers in lieu of gaskets.
Old 11-18-2007, 08:50 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Thanks again!
Once you're in there it's best to replace the whole thing, both gears and the chain. Why replace one thing only to have to go back 10,000 miles later to replace something else? They wear as a set and should be replaced as a set. Besides usually purchasing a set is more economical in pricing versus piecemeal. Sets for that car can start around $12 to $15 on up to over $200. I like to use a cork/rubber combo valve cover gaskets. Sometimes they are hard to find, but they should still be produced for that year of car.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 11-18-2007, 11:46 PM
Ok, should I get something like this set, or will there be more parts needed, like in this one?
Old 11-18-2007, 11:50 PM
silicon212's Avatar
Confoundingly Lucid
The second one you link to is definite overkill. The first one is one that I actually have in my car. The exact one. Mine now has 287,000 miles on it since new in '93 and it's been great.
Old 11-18-2007, 11:54 PM
Thanks, you just made my day . I was afraid of having to splurge out for the second set.
Thanks!
EDIT: While we're at it, I have one more question. How hard is it to replace the speedometer cable? I can get one for just $10, and my original one broke after about a week of fluctuations.
Old 11-19-2007, 01:45 AM
silicon212's Avatar
Confoundingly Lucid
Thanks!
It's not too difficult, but it is somewhat involved and you'd do good to study up on it a little. You have to remove the instrument cluster from the dashboard in order to get to the cable in the back of the speedo head - at that point, you depress a tab and the cable sheath pulls out the back. The cable is contained within the sheath, once you pull the sheath from the back of the speedo head, you simply pull the cable out through the top. Make sure you use an old towel and don't let the cable touch any upholstery, lest you wind up with a permanent stain. If the cable broke inside the speedometer head (it's plastic there), you can pull the broken piece out with an pick awl or similar. If the transmission gear broke, then you're getting underneath the car to get to that (the other end of the speedo cable sheath screws onto the gear housing, which can be removed).
When you put the thing back together, LIGHTLY grease the cable with white lithium grease.
Old 11-19-2007, 06:17 PM
Thanks again . If the gear on the tranny is stripped out, what part name would I look for for the replacement?
Old 11-19-2007, 06:24 PM
silicon212's Avatar
Confoundingly Lucid
Just a speedo driven gear. They're color coded - make sure you get the same color as what you now have, so the speedometer retains its calibration.
Old 11-19-2007, 09:56 PM
Ok, thanks again .
Would you happen to know everything I'll have to remove to get to the timing gears? I know the front end and radiator, but is there anything else?
