Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 11-18-2007, 08:29 PM
Bear Bear is offline
Oil leak
2007 Sonata with 3.3 liter V6 and she has a minor oil leak. I occasionally find a small (2" diameter) spot of oil under the engine on drivers side, I also find pooled oil in/on top of the casting where the transmission meets the trans axle. The dip stick shows oil level at the top mark, I am going to pull the engine shroud and then the air filter box to see if there are any lines or connections from the oil filter housing that are leaking, barring this, any other suggestions (I do not have service CD and Haynes does not have a manual out as yet so I have no picture of the lubrication layout). Also, no oil at drain plug or at the valve covers.
Old 11-19-2007, 07:08 AM
cmhj2000 cmhj2000 is offline
Re: Oil leak
Hyundai does have an online service manual. I'd post the link but admin here doesn't allow posting links but the url is basically hmaservice.com.
Check my home page for lubrication help.
Old 11-19-2007, 11:26 AM
Jalmir's Avatar
Jalmir Jalmir is offline
Re: Oil leak
I don't think so ... lollll
http://www.automotiveforums.com/vbul...d.php?t=340357
Old 11-19-2007, 11:30 AM
Re: Oil leak
Wasnt aware of that. The last time had posted a link to another site I was told no no. Huh?
