Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-18-2007, 01:16 PM
inkedmedic inkedmedic is offline
Still have the vibration........
Alright were do i start. I still have a high speed vibration on my 94 4runner 4wd. it comes on gradually and very unoticeable until about 75-85 then once i hit 90 it goes away all together!
This is what i have have done to try to fix the problem.
Balance tires-three times-tires are stock size.
Changed out all of the u joints.....all of them
removed my front propeller shaft
changed out the idler arm
alignment
checked disks and pads....
i am still getting the VIBRATION and it is drving me crazy! I found the front bumper bolt was loose and i tightened it, Still vibrates. Anyone please help me please. I live in CA so you know that going 70 on the freeway is slow and it is annoying the hell out of me. Thanks guys.....
Old 11-19-2007, 07:44 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Re: Still have the vibration........
Tires on Toyotas need to balanced using a lug centric method rather than the normal hub centric. Find a shop that has the Haweka lug adapter for their machine.
Don't be surprised if your Toyota dealer has no clue. Then tell them to read Toyota TSB SU002-96. Then go somewhere else that does.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 01-13-2008, 12:13 AM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Not sure what type of "vibration" you have, High frequency or body vibration?
High frequency or drive line vibration on this year can be caused by, ready for this? A lose nut! No not you, the large retaining nut on the rear output flange! Need to remove the ujoint and tighten it to the specified torque and you problem is solved. Don’t wait too long or the splines on the out put shaft will wear.
Hope this does it. Repost and let us know!
Old 01-24-2008, 06:43 PM
OzzyO's Avatar
OzzyO OzzyO is offline
Send a message via MSN to OzzyO Send a message via Yahoo to OzzyO
I also have a 94 4Runner and had the same problem a few years back, it turned out to be that one of the bolts was broken on my front skid plate, hooks under your front bumper and continues to your front suspension.
I had to drill it out and use an easy out to get it and then tapped it and put in a new bolt.
Once I got that fixed the vibration left and hasn't come back so far.
Good Luck
OzzyO
