Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-18-2007, 08:05 AM
BostonKev BostonKev is offline
01 Cvpi low lowend power
Hi All, I wanted to get some opinions on what could be causing low end power and knocking issues with this car. It's an 01 with 78k that's been sitting for a while which runs great at higher rpm's. Let me start by saying what's been replaced. I replaced one of the cat converters, all the cop's & plugs, IAC, MAF and the gas filter and drained all the gas out of the tank.
Any other suggestions? Thank you
Old 11-18-2007, 11:46 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 01 Cvpi low lowend power
Hey Kev. By any chance is the transmission starting in second gear instead of first? Just a thought.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-18-2007, 03:52 PM
nope. But I did learn a little more today W2O. I did a compression test and the entire passenger's side has zero compression. Driver's side is normal. Since it seems to run Ok at idle and higher rpms is it a safe assumption that the timing is probably 180 degrees off on the passenger's side or could it be off a tooth in either direction? Ran out of day light when I realized this info. Thank you
Old 11-30-2007, 07:00 PM
Stick462 Stick462 is offline
If you have no compression on your right engine bank then it isnt timing.you have four valves open or broken compression rings.My guess it the latter.How long was this engine sitting???
Old 12-01-2007, 09:17 PM
I finally got around to doing the teaspoon of oil test late today and still no compression so it should be valve related (theoretically). I have the valve cover off and the cam seems to be turning correctly and pushing down but I'll need to look at it closer next chance I have. Are the cams known for going? Seems impossible that the cam would go & effect an entire bank so I'm confused as to what the state did to screws this car up.
BTW it was probably sitting for a year or 2.
Old 12-03-2007, 04:34 PM
check the value springs .but ill bet its compression rings/they have siezed on the pistons.
