Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-18-2007, 04:39 AM
bsskierfolife bsskierfolife is offline
squeeling problem
well i have a 95 talon tsi awd and it was squeeling every time i started it or used heat or system or lights but then i replaced it and it didnt squeel for two days then tonight it was cold out and i dont know if that means anything but it sqeulled again starting it like a constent squeel for 30 secs i cant figure if its my alternator or something else..think its my subs?
Old 11-18-2007, 09:33 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: squeeling problem
It could be that the belt is just simply too loose, that would explain why it would squeel when it was cold because the belt hardens up a bit when it gets cold so it doesn't grab as good on the pulleys, too loose I think is your problem. Try snugging the belt up a bit more.
Old 11-18-2007, 09:42 AM
MazdaX's Avatar
MazdaX MazdaX is offline
+1 for tightening
2004 Mazda 6i
1997 Tahoe
Old 11-18-2007, 01:25 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Next time you have your belt off, spin the pulley on the alternator, and make sure it spins freely, and doesn't lock up. When you put the belt on make sure the alternators charging like it should. If all of that is good, its probably just the belt that needs tightening. Just don't overtighten it, that will cause the bearings in the alternator to wear prematurely.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-19-2007, 03:15 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Whatever you do, do NOT put that belt shit on them to stop the squeeling, it'll just make it worse in the long run. Tighten the belts and the squeeling will go away, UNLESS you have a fluid that's dripping onto the belts from somewhere. I had a coolant leak that would drip on the accessory belt from time to time and made an awful squeeling noise, fixed the leak and no more squeel.
95 Talon TSI AWD
97 Eclipse GST
Old 11-19-2007, 09:33 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
How about you take the idler pulley off and slap some grease in there between the bearing and the pulley itself. If there is no grease in there it doesn't matter how many times you tighten it, its gonna squel like bastard, maybe even loosen up.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-19-2007, 11:52 PM
The pulley itself wouldn't make a loud squealing noise if it was dry, it would make more of a grinding noise, but lubing it up never hurts either.
95 Talon TSI AWD
97 Eclipse GST
Old 11-20-2007, 12:29 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Aw man, I thought this was a thread about Brian's mom's squeeling problem.
As for the belt, are you sure the pulleys are in line? What about the alternator, is it bolted down hard?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-20-2007, 01:04 AM
She squeals too? Damn. I thought that with all the noises she makes when she's with me she'd have no vocal cords left to make a high pitched tone.
95 Talon TSI AWD
97 Eclipse GST
Old 11-24-2007, 01:17 AM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
when I floor my car in 3rd at 60 mph it squeals too. I'm hoping to get an AWD swap that will fix that problem though..
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
