Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-17-2007, 10:03 PM
rickyrickster25's Avatar
rickyrickster25 rickyrickster25 is offline
Pulley ?
Would it be worthwile to get all new pulleys instead of just a new UDP?
97' Eclipse RS 5 Speed 420A
Under The Hood:
Bomz UDP, Custom CAI, NGK Plugs, Mopar Wires
Interior:
Blue Glow Dash Guages & HVAC Controls, Neon Accents, Custom Dash Work\Paint, Alpine Type-R/JL Audio System, Custom Trunk Layout
*GOAL* - Prove Him Wrong
Originally Posted by UnderEstimate Me
I doubt bolt-ons will get you to 160hp on the 420a. Unless you have some dyno sheets Im calling bs.
Old 11-17-2007, 10:28 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Pulley ?
UDP would give you the most gain. The others you wouldn't even notice a difference.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-17-2007, 10:41 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: Pulley ?
What do you mean UDP? Underweight Drive Pullyes?
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-18-2007, 12:13 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: Pulley ?
under-drive pulley. As in its smaller and under-drives the accessories, freeing up power.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 11-18-2007, 08:16 AM
Re: Pulley ?
Thanks
Under The Hood:
Interior:
Old 11-18-2007, 11:54 AM
Holset powered 420a
Re: Pulley ?
UDP are also lighter. My stock harmonic balence pulley weighed about 7lbs. My aluminum UDP weighed a like 1.7lbs.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2007, 04:09 PM
Re: Pulley ?
You took off the harmonic balancer?
Caleb
vanilla gorilla
Old 11-18-2007, 05:31 PM
Holset powered 420a
Re: Pulley ?
That would be what the UDP replaces. So yes I did.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2007, 07:47 PM
JoeShmoe's Avatar
Re: Pulley ?
So there really is a big difference if you get a full set. What about voltage drop?
Old 11-18-2007, 07:50 PM
Holset powered 420a
Re: Pulley ?
I wouldn't spend the money on a full set. Just the crank pulley is all thats needed. I doubt the others will give you any power. You should gain a few whp with a UDP.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2007, 08:20 PM
Re: Pulley ?
Oh I wasn't sure if on your car the harmonic balancer was made onto the pully or not. Some cars, like our ol' Z28 Cam, have the harmonic balancer and crank pulley as two seperate pieces that bolt together. We put on an UDP on this car and keep the stock balancer as well.
But yea, your car has a one piece pulley and balancer, so you done away with the harmonic balancer....is that a good idea? On my eclipse I took the balance shafts out but kept the harmonic balancer. My honda doesnt have balance shafts or a harmonic balancer...
Caleb
vanilla gorilla
Old 11-18-2007, 08:24 PM
Holset powered 420a
Re: Pulley ?
I have "heard" that it can wear bearing out prematurely or even snap a crank. All of this info was hear-say and there was no evidence to back it up. I have never seen any evidence that removing the harmonic balence has caused a motor to fail. The UDP is machined out of aluminum so it should be balenced as is. It not a bad idea to check the balence on it before you put it on just to make sure its not off real bad. Thats the only thing I could see causing problems.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-18-2007, 08:47 PM
Re: Pulley ?
Yea I see what your saying. I was going to put one on my eclipse but It just doesnt seem like a good idea, especially since I took the balance shafts out, it vibrates bad enough already.
Caleb
vanilla gorilla
Old 11-19-2007, 02:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Pulley ?
I've never heard of anyone having trouble switching to a UDP. It would have to be way out of balance to cause any real damage, and it would vibrate like a BITCH. I think it's worth it for the power gain you get.
95 Talon TSI AWD
97 Eclipse GST
