Old 11-17-2007, 06:50 PM
bluebuick91 bluebuick91 is offline
97 blazer won't start
97 4dr 4.3 l fuel injected has been sitting a few months got it started ran awhile them quit battery went bad put a new one in turns over but wont start you can smell gas like its flooded but i cant get it started to use my code reader.
now a friend gave me a jump start when i was having a battery problem hope this did not hurt anything.
any help thank you all
and my son just changed plugs before all this started
Old 11-17-2007, 09:20 PM
Wags391 Wags391 is offline
10-year Owner
Re: 97 blazer won't start
A few suggestions: bad gas, bad alternator, distributer rotor/cap, plug wires, were the new plugs properly gapped, was the coil wire replaced correctly. I would check these items first. Of course, check for bad gas as a last resort.
Old 11-18-2007, 10:12 AM
checked the alt it works fine. had a bad battery put in a new one with 640cca is this battery to small everything is electric on it.
it was running fine after the the plugs were changed but it seemed as if you had to pump the gas pedal to start it and you shouldn't have to right it is FI.
its sitting at my sons 50 miles away right now but i will be going down there tomorrow and i will check the rotor wires.
my son said it turns over fine but won't start and he smells gas from the engine.
Old 11-19-2007, 02:49 AM
DelCoch's Avatar
DelCoch DelCoch is offline
Make sure the new battery is fully charged. A weak battery, even when it will turn the engine over good, will cause a no start problem. I would try to jump it and see if it starts. If not, then start with checking the fuel pressure with a pressure gauge.
Keep in mind that '97's are notorious for bad ignition switches.
