1998 Protege - Rim Size
Hi - I'm looking for used Winter Tires for my car and need to determine the required rim size. Unfortuantely I got my car used and it did not come with an Owner's Manual. It's clearly 4 bolts, and by measuring it seems that the bolts are 100mm across from each other. (The current tires are 185/65R14 too).
I am concerned that there are factors other than bolt pattern that I should be aware of. For example, I found some tires that used to be on a 2005 Honda Civic (which have the 4x100 bolt pattern) - will they fit properly?
Thanks for any help anyone can give.
