Old 11-17-2007, 03:46 PM
StarLover StarLover is offline
Send a message via AIM to StarLover Send a message via MSN to StarLover
1996 Cavalier Clutch problem
About a month ago the clutch fluid res leaked out completely somehow. When this happened my clutch lost all pressure. To put a temporary fix on the problem I had to change the fluid in the res at least twice a week because it would get very dark and dirty. After a while of that I replaced the Master cylinder for the clutch. It seemed to be find for about 4-5 days. Now its lost all pressure again, and the fluid looks perfectly normal. I'm completely stumped on what is causing this. Any ideas?
Old 11-17-2007, 04:56 PM
muff34 muff34 is offline
Re: 1996 Cavalier Clutch problem
clutch release cylinder or line going to it is leaking.
Life Is A Highway ,Enjoy The Ride
Old 11-17-2007, 05:00 PM
Dont get me wrong, isnt that the same thing as the Master cylinder?
Old 11-17-2007, 08:08 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
no, the master cylinder has to do with the brakes, it has nothing to do with the clutch
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-17-2007, 08:14 PM
No I mean the Master Cylinder for the clutch.
Old 11-17-2007, 09:10 PM
no this cylinder I am refering to is down below which is located on left side of clutch housing . I know which one you are refering to and it is located up top for the clutch and will likely be smaller than the master cylinder for brakes. Here chech this out .as you can see it is also called a slave cylinder http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 11-19-2007, 02:37 AM
16th hippy 16th hippy is offline
hate to ask this, but did you bleed it real well? i had one that i bled a buttload, drove it, and a freaking bubble surfaced out of nowhere, bled once more and all was well.
Old 11-19-2007, 08:50 AM
Yeah My dad helped me bleed it.
Old 11-19-2007, 07:16 PM
So Today I bled the clutch after the 4th time and wala! It works just fine again... although now.... I have a fuel line problem... I think its the fuel filter... Hoping its not the pump...
