Old 11-17-2007, 03:12 PM
carguyvr4 carguyvr4 is offline
Send a message via AIM to carguyvr4
Where can i find?
Where can i find a labled diagram of the interior fuse box and relays, I'm trying to find the fuel pump relay, my car died out on me and i have a feeling that might be it, its a crank but no start, it died on me on the way to work the one day after doing a throttle body gasket, but everything is connected
Old 11-17-2007, 06:05 PM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Re: Where can i find?
I beleive the fuel pump relay is also called the MFI relay and is located on the side of the center console on the passenger side. right beside the left calf of the passenger.
you do have to take the panels off but its not too hard, look on stealth316.com for the ecu removal and it will show you how to take those panels off.
is there a clicking coming from the passenger side interior?
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 11-17-2007, 06:52 PM
It's kidna ahrd to tell with the noise taht goes on while turning the car on lol.. i pulled the one line going to the fuel rail gas poured out so im taken it as its getting fuel.. didnt check the coil yet but only other thing i can think of is the cam or crank sensor... fuses are all good..... is the cam n crank sensor VRS?
