Old 11-17-2007, 12:19 PM
Theessence's Avatar
Theessence Theessence is offline
Washer Fluid hose
The tube that goes from the washer fluid resevoir to the wipers is disconnected at the resevoir end. I have the tube with an 'L' shaped rubber connector on the end hanging out. Where is the place where you connect the line so I can get to it from the appropriate side. If its in the back then I'd probably take off the fender splash shield but if its in the front it may be easier to take out the battery and the plate that the battery sits on.
I'm looking through my repair manual but I'm not finding any information on the topic. What do you think is the best way for me to do this. Oh also, I don't have a garage and its mighty cold out in these parts.
Thanks
Old 11-17-2007, 05:32 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Washer Fluid hose
Yeah the only way is through the splash shield.
A 2-3 bolts up front on the lower splash shield, and then the 5-6 push pins around the fender edge.
How'd it come loose.. ?
1999 Grand Am SS 3.4 OHV
Old 11-17-2007, 06:43 PM
Theessence's Avatar
I'm not 100% sure but I just had my front bumper replace and the mounting bracket thing that the headlight goes into so theres a good chance it happened then. Thing is, the light was on for low fluid before all of that. I hope the whole resevoir isn't cracked or something.
