Old 11-17-2007, 11:28 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
Headlight woes :-o
STEALTHEE!
ok, my dash lights and parking lights and headlights will not work.... turns and hazards are fine.
checked the tail fuses, checked the headlight switch. switched the relay out with a different one (tail relay) and still nothing... is there a fuse or something im missing?
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 11-18-2007, 10:26 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Headlight woes :-o
Check the battery fusible link. If its blown none of that will work unless the switch is on. There could also be other fuses blown.
Have you done any wiring of anything lately?
Old 11-18-2007, 11:10 PM
joecaruso joecaruso is offline
Banned
Yea you remember this water head was wiring LED snake eye lights. Now he's blown his whole electrical system up.
Old 11-18-2007, 11:30 PM
Stealthee's Avatar
I think I might have found the second ever member of my Ignore list.
Dont feed the trolls liquid.
Old 11-19-2007, 12:13 AM
liquidPunk's Avatar
Off my thread trog! So i had gathered that you couldnt read joe, but now you have no concept of time either? the led snake eyes were a few weeks ago silly boy.
anyway stealthee, I was looking under the fusebox to familiarize myself with it so i could rewire the fogs as in that other thread, but im gussing i have a crappy wire somewhere becasue when i snapped it all back together nothing worked, not really sure honestly, but ill look into the fusable link. if i can find it
-More to come-
Old 11-19-2007, 12:19 AM
Stealthee's Avatar
The battery fusible link looks like a large fuse. Its the middle one all the way to the left when facing the car.
Another thing to check is the IOD plug in. Its a yellowish green looking thing directly next to the battery fusible link. Without it (or if its loose) alot of shit wont work.
If none of that works you need to go back to the fuse box and make sure no wires got knocked loose.
Old 11-19-2007, 07:50 AM
blu3kgt blu3kgt is offline
the same thing happened to me and it turned out to be the headlight switch.... have you took it out and tested each terminal inside of it... that is what i did and thats the way i was able to determine that was it.... when you put the key in do your high beam still come on along with your turn signals and hazards??? if so i am most certain that is your problem, the headlight switch on the steering column
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 11-19-2007, 09:06 AM
liquidPunk's Avatar
No, I have already replaced the switch, i saw your thread and went ahead and replaced mine (the letters were faded anyway). but no high beams with the key either. jus hazards and turns, I know the bulbs can get power because the turns work, so it must be something in the parking lights circit.
and thanks Stealthee, I'll look into those tom after work, man i hate wintertime with the shortened daylight hours, ugh.
-More to come-
Old 11-19-2007, 01:42 PM
Crackhedbob341's Avatar
Crackhedbob341 Crackhedbob341 is offline
just a suggestion...
but when i installed my alarm, i had to take out the dimmer switch (forgot the fancy name for it) and had to unplug it. just grab a flat head and pop it out and make sure the harnesses are connected right.
probably not the problem.. BUT i know my lights (headlights, interior, and highbeams) wouldn't work without that being plugged in right.
Never bring show to a go fight.
And a TT conversion brewing..
Old 11-19-2007, 05:21 PM
vectorspecialist vectorspecialist is offline
just stopping by to say i'm number one!!! haha
yup, here i am
Old 11-19-2007, 05:24 PM
Stealthee's Avatar
LOL, you never made it there vector.
It was some pain in the ass kid who typed worse than even you. :lmao:
Old 11-20-2007, 06:41 AM
damn, o well better luck for me next yr. neways since i'm not useful for this thread...later
yup, here i am
