problem!!!
i really don't kno whats wrong wih it. i woke up drove to the bank and win i was gettin ready to leave the car didn't start. usually win i crank up the car ill hear the fuel being pumped but not this time ....... i had a machanic look at it and he said its the distributer or ignition .i think its the fuel pump but am not sertin does anyone have an idea of what it might be??????
Re: problem!!!
Could likely be the main relay. Have you tried starting it since?
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Re: problem!!!
Check all fuses under your dash and engine bay first..all meaning, every single one.
AF Bay Area Crew![]() Fully Built LSVtec Motor (245.8 whp/164.6 torque) 88 DX Hatch to JDM SiR conversion Retired SOLD 1/08 Licensed Mortgage Consultant (Calif.) Cellular 415.699.1797 |
Re: problem!!!
for the main relay... if you don't hear a click, you car's bein a dick. ![]() Someone please come up w/ a better catch phrase for that common problem... and make it rhyme. Last edited by Christ; 11-18-2007 at 12:16 PM. Reason: just because. |
Re: problem!!!
i tried starting it and nothing and i checked all fuses and i dont know how to get to the main relay
Re: problem!!!
Its behind the change holder, left of the steering wheel. Inside the dash.
Re: problem!!!
Main relay is right above the hood release lever.
Re: problem!!!
just listen for a click when you turn the car on, before you try to start it... does it even crank? or no crank at all?
If you hear the click, watch for your check engine light to blink, it will come on, then blink off after about 1 second.. (it's the ECU test sequence) |
Re: problem!!!
well i dont hear any noise at all and the check engine light doesn't turn on so does the mean it's the main relay?
Re: problem!!!
have you checked to see if the battery has any juice in it?
if nothing else is wrong (fuses), then, yes, it's the main relay. |
Re: problem!!!
When you say, "Car won't start," Does it crank at all? Is there power or lights in your dash? Can you describe fully? Did you check your ecu for codes?
Re: problem!!!
yes the lights in the dash turn on and it does crank but no start .... i changed the relay and syill no go .... battery is good.... and as 4 the ECU i dont know where its located at and dont kno how to check for codes............ thanx for all the help from everybody i really appreciate it |
Re: problem!!!
Ecu is under the carpet on the passenger footwell. Pull it back and look in the little window in the middle, a red led will blink if you have codes, count the blinks, with short pauses between each code. And a long pause when the sequence restarts. Read it 2-3 times to make sure.
Re: problem!!!
it jus blinks once thats all win i try to start it all i hear is two clicks from the relay,the check engine light turns on and the car cranks but no start ,the ecu blinks once but there in no fuel goin to the engine ... any more ideas.................thanks for all the advice eveyone
Re: problem!!!
well, if you know there's no fuel going to the engine, you should already know how to fix it.. there aren't too many parts to the fuel system...
after you crank on it for awhile, do you smell gas? if you do, it's getting fuel... check your plugs/wires/dizzy/rotor for spark, debris, burns, etc. check your timing belt... (if it's broken, the cam isn't spinning, so no spark, and the engine will still crank, but it will sound funny) Hrm.. trying to think of other things.. you hear the relay, do you hear the fuel pump prime? have someone turn the key on and listen w/ your head in the trunk area, for a buzzing noise. only other thing I can think of is ground wires. check them all. there is one on the engine valve cover, goes to rad bracket... there is one on the tranny, goes to under battery tray, and there is one bolted to the thermostat housing, check any others you find, they can stop your vehicle from starting, but as of now, the mechanic is sounding correct... seems like no spark, or no fuel. |
