Old 11-17-2007, 05:18 AM
mark121268 mark121268 is offline
Question 1995 sunfire stumped
hello to all first post hope ya all can help me out , well here it goes
when I am at a stop I am getting like a misfire but it does not stall , or
as some may say ruff idle. lights in dash will dime a bit when this happens
,and more so when I have the heat on high.now things I have done to this
car,
put new injector in as other had a leak.
blower motor rely went ,and also come to find out that the motor had a dead
spot in it to (real impressed with having to get under there again)
have changed the fuel filter
have put fuel injector cleaner in it
have checked for bad ground, dielectric grease on the batter posts
have had battery and alternator checked both are working fine .
system diagnostics done no falts detected.
new coil pacs later summer , but the ruff idle just started so don't think
it has to do with that
do any of you have any ideas to what I can do next to figure this problem
out ?
thanks in advance for any help that you ppl may provide
Old 11-30-2007, 11:58 AM
Denedil Denedil is offline
Re: 1995 sunfire stumped
I have something similar happen, when my radiator fan kicks in.... car will vibrate some, and the lights dim a bit.
If your running hot, and the fan is having to kick on as soon as you quit moving, *shrugs*
Just my .
Old 11-30-2007, 03:46 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Engine size would be helpful. Check plugs and wires. If no wires (2.4L), try replacing the plastic "cover" over the engine. Those go bad and cause a rough idle. I've also seen a failing ignition module cause that.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 12-01-2007, 07:10 AM
sorry for not posting engine size , is 2.2
