Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-17-2007, 01:11 AM
billheb billheb is offline
94 3.8 cranks,no start
Brand new here guys so hello,I'm doing a freebie job for a family member here and I'm sure most of you guys probably been there too.its a 1994 3.8 5 speed,38 lbs of fuel pressure,it is jumping my spark tester so its firing,firing in order-I dont know,it seems as if the engine runs the same rpm or speed as the starter motor does but dies when the key is released from start to run it dies,if you can call that running,it also pops or backfires through the intake.Thanks in advance for any suggestions or tips
Old 11-18-2007, 11:35 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: 94 3.8 cranks,no start
I worked on a '97 camaro that had the same problem. It was just a corroded coil/wire connection.
1969 Cougar
357w & TKO - 475hp
