Old 11-16-2007, 11:23 PM
thingken thingken is offline
OBD I with OBD II plug connector
I have a 95 jimmy with a obd II style connection (no compliant stickers anywhere). I've tried kragen and autozone scanners, their unable to establish a connection. Sure would appreciate any tips on extracting codes from this vehicle.
Old 11-16-2007, 11:50 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: OBD I with OBD II plug connector
95's used 3 or 4 different computer system types as it was a transition year. some systems were still obd 1 but with the obd2 connector. an obd 2 only scanner will not work on this system. you need a scanner with an obd 2 cable that reads both obd types like an actron, snap on, etc. if the connector does not supply the scanner with power (like an actual obd 2 equiped vehicle) then the scanner should include a cable to tap power from the cigarette lighter. hope this helps you.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
