Transmission Squeak ????
Driving with the windows down today I notice a squeaking noise coming from the underside. I thought... 78,000 and now it needs u-joints. After I returned home I jacked up the rear and turned the driveshaft with the trans in neutral. The squeak was not from the u-joints, but from the trans tailhousing. Any thoughts???? I initially thought that the seal that rides on the rear yolk was dry. I shot some thin lube into the seal... no change..
I'm stumped.. I guess the next step is to pull the drive shaft and see if there is any scoring on the the rear yolk and replace the rear seal... It's a 2002. |
Re: Transmission Squeak ????
i am assuming the squeak gets faster with vehicle speed. try removing the driveshaft and moving the slip yoke and rear u-joint in both directions. the squeak of a u-joint can travel through the shaft and be misleading sometimes. let us know!
'02 Suburban LT '03 Lexus ES300 '93 Mustang (EFI 408, 10.56 1/4 on 93 octane.. all motor).... |
ok....i hate squeaks...lol
Thanks.
