Riding in the cold
Had to go to a meeting today at 9 am, decided to take the bike although it was pretty chilly. There just seems to be more flavor to the experience in the cold.
The bike is trickier to start. You hear everything in the motor while that 20W50 creeps to the top end. Gotta feather the choke, it's cranky until it's been rode several miles. Even at that point, the oil is still heavy enough that it makes the clutch drag a bit, and the cold cogs with the syrupy oil are clunky...likes to false nuetral and jumps like a nervous cat when dropped into first from nuetral...motor has a throatier sound in the cold air, once warmed up the motor dotes on the dense, dry air. Hesitant and saggy at first, throttle response is sharp and acceleration is better than ever once we get off the choke. Gotta warm up the tires...hard as rocks at first, come into compliance as I weave gently side to side to wake up the cold rubber...turn signal doesn't want to flash for the first few turns. Cranky old bike slowly gathers it's composure and works out the kinks, taking it's time to warm up and greet the day. I can relate completely. And running down the highway in the 80 mph wind chill, I want to smile as I realize after the first few miles I'm so cold I can no longer feel it. But I don't, mostly because I'm afraid my face will shatter
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made... ...empty gun rack. |
Re: Riding in the cold
haha I can totally relate... except for the bikes crankyness. If anything mine runs better in the cold. and the extra power is a BLAST!
My blazer broke down months ago in the nice warm summer months. I kinda just let it sit and used my bike for everything all summer and all Fall. Now I'm really starting to think that I should have fixed my blazer before it got so cold here. riding to work in November weather of New york is no fun. Its in the low to mid thirties some mornings and i get so numb on my short 3 mile commute that I can barely turn my bike i'm so stiff haha. Haha as a matter of fact I specifically put off everything this weekend just to set time aside to work on my blazer and I'm sitting here wasting daylight and warmth procrastinating on AF haha. WTF is wrong with me.
Old: 1993 Acura integra gs-r New: 1998 chevy BlaZeR2~ AKA "Jeep recovery device" Newer: 2007 Honda CB900F "919" |
I Ride A 98 Zx11. Why Is It That It Rides So Much Better In The Cold? She Sounds Great.. Idles Steadily... And Rips When I Crack The Throttle.
es_class BEFORE AFTER SWEET-ZX11
2000 Cadillac STS 2005 Cadillac Escalade 2008 Triumph Sprint ST 1050 ABS |
Humidity in the air displaces oxygen and nitrogen, cold air is denser (more molecules in a given volume) and drier (cold air doesn't carry moisture as well as warm)...plus you probably get some expansion effect with the fuel when it comes to the motor colder...gasoline expands and contracts with temp wildly (ever top a tank or can on a cool morning, and find it running over in the afternoon?) so you probably deliver more fuel volume in a given charge too, like caddydaddy said...
If your idle is better in the cold, you are probably jetted a bit too rich...but I prefer a slightly rich mix on a bike, better for performance and won't harm anything, outside of sooting the plugs a bit. Too lean can cause damage.
wow i didnt know this. very interesting. i thought rich was bad.... and lean was better. what kind of damage we talking here?
Yeah it's kinda hard to hurt anything with a rich mix. Rich gives more quench to valves and combustion chambers, beyond a certain point you get so rich you run into spontaneous afterburn in the exhaust when the hot unburned fuel meets the oxygen available in the exhaust and reignites...you don't want to be so rich you are fouling plugs evey time you start it, but I'm suspicious of a cycle motor that has zero soot in the tailpipes...fuel injection however can run it closer to stoich and still perform well, so with FI it's not as critical...
But lean mixes run very hot in the combustion chamber, and overheat exhaust valves, piston crowns and exhaust manifolds... When looking at chrome pipes, a bit of mellow gold tint near the exhaust ports usually indicates a slightly rich mix like I like to see...it can also happen if run on the choke too long....but when you see them toasted and cooked varying hues of blue and purple, that motor is too lean...exhaust is torching the pipe at the bend with hot gases... A lean mix will preignite and knock, and can cause intake backfire on sudden demand or under load.... And part of a spark plug's ability to fire has to do with ionization of the plug gap...at the pressures and temp in a running engine, it's harder for spark to jump the gap than in a static condition (outside of the cylinder)...ionization of the intake charge's gases creates an optimal path for spark to jump the gap...if the mix is too lean, ionization fails to occur and the cylinder experiences a lean misfire....
This is probably why my bike is alot smoother in the cool air. It runs way rich straight from the factory. Its actually a common thing with 919's I've heard. I always stink like fuel and exhaust even after short rides, and I've been told by friends that some smoke shoots out when I punch it. but since its gotten colder I haven't noticed the smell much
Ideally you want to use all the fuel that goes into it, but like I said a little rich is cheap insurance...keeps things cool and means there is always sufficient fuel available on demand. Unless your plugs come out of the motor looking like charcoal, it's all good...
Nono. FAr too cold and wet. I hate the cold. I hate RIDING in anything below 60* Even in the 60's pisses me off. Give me a 95* day in a helmet, leather jacket, gloves and heavy pants anyday. Plus it seems like the other people on the road drive worse when its cold.
It's exhilarating to come in from a ride when it's cool. Granted, I don't have a bike right now, and our highs are barely in the 40s, but I have had to scrape frost off my seat before... that was more stupid than fun, but I'm rambling now and... yeah...
Like a boy - but BETTER! 2005 Subaru Forester 2.5X 1997 Honda Civic EX Coupe Inform yourself: AF User Guidelines |
I won't even ride once the temp is over 90...it's miserable to me... ![]() Whoops...I see speediva already fielded this one...
No way i'll sweat in my helmet all day with a big stupid grin on my face. The heat from the motor roasting my legs in traffic, the radiator fan kickin on at 225* to add even more heat... sweat dripping down my face under my helmet, the leathers heating up my arms and back, and the wet spot on my butt from all the accumulated butt and ballsweat. Yeah, give me that over the cold any day, any way. Plus it's not even so bad once you get going, and a nice hot road = gooey sticky tires.
It was 30 degrees out today and I went for a 44 mile ride. I was a bit cold at the end, but it was very enjoyable! The cold air adds an extra power punch! I have a pair of heated gloves that I'll be using for when it gets real cold.
