Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 11-16-2007, 06:35 PM
hallee hallee is offline
Brake light bulb 91 cont
Need to replace brake light. Took out screws holding assembly but no luck getting it off. Any suggestions? Thanks
Old 11-17-2007, 02:20 PM
Ramjet_FL Ramjet_FL is offline
Re: Brake light bulb 91 cont
I have a 98 I had two replace the right brake light the was five or six nuts. The light assembly was very snug it also had one that was inset closer to the light than the rest of them. Good luck.
Old 11-17-2007, 05:21 PM
Towncar's Avatar
Towncar Towncar is offline
Here's more details, 1991 Specific
Rear Turn Signal, Brake & Parking Lights
1. Open the trunk and remove the luggage compartment trim.
2. Remove the eight nuts retaining the reflector to lower back of luggage compartment
3. Remove the rear panel reflector assembly from the vehicle.
To install:
4. Installation is the reversal of the removal procedure.
Pull the trunk trim away from the lamp housing assembly
Twist the socket assembly and remove it from the housing
Depress and twist this type of bulb counterclockwise, then pull the bulb straight from its socket
1. Depending on the vehicle and bulb application, either unscrew and remove the lens or disengage the bulb and socket assembly from the rear of the lens housing.
2. To remove a light bulb with retaining pins from its socket, grasp the bulb, then gently depress and twist it 1/8 turn counterclockwise, and pull it from the socket.
To install:
3. Before installing a light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion or dirt.
NOTE
Before installing the light bulb, note the positions of the two retaining pins on the bulb. They will likely be at different heights on the bulb, to ensure that the bulb is installed correctly. If, when installing the bulb, it does not turn easily, do not force it. Remove the bulb and rotate it 180 degrees from its former position, then reinsert it into the bulb socket.
4. Insert the light bulb into the socket and, while depressing the bulb, twist it 1/8 turn clockwise until the two pins on the light bulb are properly engaged in the socket.
5. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct if necessary.
6. If applicable, install the socket and bulb assembly into the rear of the lens housing; otherwise, install the lens over the bulb.
-Steven
1996 Town Car, Cartier
