Did the dealership lie to me?
Im helping out a friend with a 2000 Impala w/3.4 OHV. I had to change the lower intake gaskets and water pump gaskets. I called the dealer to get the torque for the rocker arms. They told me 15 Nm. I double checked with them cause it seems like a helll of a lot of torque but they said the same thing. As I was tightening the first bolt it felt like way too much torque so I stopped and lowered my setting to 10Nm. At the same time the torque wrench clicked I heard a crack...im like OMG WTF??? So now I tightened the next one but no crack. When I got to the 5th one I heard a crack again. I took the 5 rockers all the way off to see what broke and it was the spacer under the rocker. 2 out of 5 broke so now im scared to do the other 7. I called the dealer back and he said he doesnt know y they broke...wtf?
Did he give me the right info and these spacers just break like that or what? Has anyone ever heard of this before? oh yeah, I know im a retard for continuing to tighten the rockers after the first one broke Thanks for ur help in advance
![]() 97 Seville STS 95 Lumina about to get a 3.8 supercharged 97 Mustang 3.8 06 Charger RT 5.7 Check out the 1 of a kind whips http://www.cardomain.com/id/NoctrnlCreations |
Re: Did the dealership lie to me?
On line conversion shows that is about 10.5 lb/ft of torque no way that should happen, check the wrench or you work procedure, or pushrod lengths were switched, something.
what was 15Nm on one side was around 110ft lbs on the other side of the wrench. that has to be too much
Does anybody know the rocker arm torque on a 2000 Impala w/3.4 OHV?
14 ft. lbs. (19 Nm) plus 30 degrees....
you could buy the rocker arm tool so you wouldn't have to loosen them. ~$15 to save time.
That sounds useful, I didnt know they made a tool like that. Thanks for all the help guys...as always this forum kicks @ss. The service manager is gonna find me some spacers for free
It is basically a valve spring compressor that allows the rocker arm to be freed up enough to slip the pushrod out, Snap On and Mac tools both have them. It is a time saver, but for a one time job most people will take the longer route, a time based service dept's techs really can use it.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
im gonna have to buy that, i've only seen the one to compress the valve springs
I dont have a lot of time to work on cars these days because I started doing home remodeling again as a contractor but I still customize cars...its my passion and im not blaming the service manager, it was my fault. These guys r just cool and let me have cheap parts if they have them in their tool box. I got a new torque wrench and read it wrong but atleast my gut feeling was right, I just didnt listen to it like I should have. Oh well, we live and we learn
get a torque guide so that you will know approx. how much to torque your hardware. all beginners need to use torque wrenches until they have learned when too much cranking will break the fasteners. 110 ft lbs is good for 9/16inch bolts.then you should get familiar with fastener hardness grades, etc..even the professionals break bolts. I bet you'll still saved alot of money doing this yourself. keep learning and over the years you will save $$$$$.........
matco has them too, they even have the shorter one for the venture vans...the long one won't fit for the front bank.
thanks guys. Im not really new to this, thats how I new it was too much torque from feel. This new torque wrench just threw me off. I do more suspensions than anything so on motors I have to slow down and question torque specs. The one side of my wrench says: daN.m, I thought it was the same as N.m but obviously not.
The real caution is the Motors Manuals and Chiltons as well have errors and must be checked thoroughly before using the info ie: Motors has the torque listed as 14 inch lbs on one chart and 14 ft lbs plus 30 degrees on another and Chiltons has it 89 Nm 10 inch lbs. so it is good to double check the numbers....Wouldn't be nice if the dealers had a library of manuals for use by customers....just a thought....
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
