Old 11-16-2007, 05:29 PM
fynd fynd is offline
98 Cavalier - Stalling, crank sensor, codes
Codes showing crank sensor malfunction
- we put in a new crank sensor but it made no difference, same problem
Car is running rough
- Stalling, RPM needle jumping up and down, lights on dash flickering on and off
All sensors replaced (at least once or twice)
New fuel pump
New injectors
EGR valve checked
Computer checked
We've put over $4,000 into this car and have been to many different mechanics, pretty desperate here
Please help :0
Old 02-11-2008, 12:50 AM
dpannazzo dpannazzo is offline
Re: 98 Cavalier - Stalling, crank sensor, codes
I do not know if this will help.
I have read on other boards (Club Cav) that when you replace the Crankshaft sensor the computer needs to be re-learned as to the new distance between the sensor and the crankshaft. It also stated it needs to be done with a Tech 1 or 2 scan tool.
Can you help me? I replaced a 1995 2.2 OHV engine with a 1998 2.2 OHV engine. The PCM is new, I have spark but the injectors are not firing. I went to replace the Crankshaft sensor and instead of having 2 wires (Purple & Yellow) as shown in the Chiltons book and online at ALLDATADIY it has 1 black wire. It is the Crankshaft sensor as I removed the old one and it matches the new one.
Do you know how many wires and what color were on your sensor.
Thank You.
[email protected]
Old 02-23-2008, 09:54 AM
twuke31 twuke31 is offline
Hey I am having the same problem with my 96 Z24 between 1000 and 3000 rpms there is a dead spot but if I floor it its fine. It coded that crank sensor as well just wondering if you have figured anything out?
Old 03-05-2008, 11:52 PM
poppyrodregues poppyrodregues is offline
Have either one of you tried to check the TPS (throttle position sensor). A friend of mine was having the same problem with his 98 cav 2.1. He checked the TPS and it had a dead spot in it and changed it. And it fixed the problem. hope it works for you guys too.
Old 03-06-2008, 06:52 AM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
What kind of plugs are you using?
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
