Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 11-16-2007, 11:38 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Wideband Time
Early early next spring I'm taking the car to the dyno and going to get her tuned up and put down some numbers. Then taking to track and putting down some times. So, I'm going to buy a WBO2. I don't need top of the line, but looking at different ones some have computer hookups, complicated wiring and so on. I just want something basically plug and play. Wire up a control somewhere and get the read out right there.
And then what would the right ratio be for n/t? Is it still 14.1 or something? Enlighten me please
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-16-2007, 12:15 PM
steviek's Avatar
steviek steviek is offline
Re: Wideband Time
14.1 is way too lean. It should be 14.7 at idle. And under load you should be around 11.5-12 since you are NT.
Turbo's must run richer because of detonation.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 11-16-2007, 12:38 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Wideband Time
14.7 is correct at idle, turbo cars run 11.5-12af. That is WAY to rich for nt cars. I think in the low 14's is were you want to be. Might want to search a little just to make sure.
As far as a cheap WBo2 I have heard alot of good things about JAW. Depending on how you set it up you could have it done for around $100.
http://www.14point7.com/JAW/JAW.htm
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-16-2007, 12:59 PM
david-b's Avatar
Dave is THAT guy
Re: Wideband Time
Wait so you can just buy the DIY kit and that's basically it then? Damn! I may get that. Plus then I can mount the screen wherever, and the unit where ever also.
75 Monte Carlo
Old 11-16-2007, 01:01 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Wideband Time
I saw a DIY wideband kit the other day either on tuners or 2gnt, I'll see if I can find it. It was pretty cool, and not too expensive IIRC.
95 Talon TSI AWD
97 Eclipse GST
Old 11-16-2007, 09:47 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: Wideband Time
I have the AEM wideband and it was plug and play pretty much. Only thing I had to do was take off the downpipe and have an exhaust shop weld on the o2 flange for it. But other than that, there was no complicated wiring and I had the wires ran and hooked up in less than a half hour.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-17-2007, 01:24 AM
steviek's Avatar
Re: Wideband Time
our target AFR should be around 14.7:1 in vacuum, around 12.5:1 at static, and around 11.5-11.0:1 as you approach your peak boost level. This will achieve the best fuel economy while supporting for lots of airflow. I'd play it safer and run richer if I was you. Personally I think the sweet spot has been about 10.5 on pump 94. This is through a lot of testing and wideband logging so I really wouldn't run 14.1 if I was you.
Or you Silvr. Static is where you would be with no boost pressure.
http://www.angelfire.com/pro2/rst/ai...uning_tips.htm
Written at 2gnt.com<--------
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 11-17-2007, 10:51 AM
Holset powered 420a
Re: Wideband Time
Steviek - You are right with what your saying for a BOOSTED car. Dave is not boosted. His car is still naturally aspired. There is no need to run an 11.5AF ratio.
EDIT - Just looked up the a/f ratio for a NA car. 12.8-13 is the target a/f
98 Eclipse GS Turbo
2001 BMW 325i - DD
