Old 11-16-2007, 08:34 AM
FordBoss88 FordBoss88 is offline
Cabin Lights
It is starting to get cold here in Oklahoma.
This happens every year when it gets cold. My dome lights do not come on for about two minutes. In fact, non of the electrical comes on except the starter. Windows will not roll down, no radio and then "BAM" everything just comes on. What is the deal?
Thank You
Old 11-16-2007, 05:27 PM
mwt47's Avatar
mwt47 mwt47 is offline
Re: Cabin Lights
Might be able to help you if you told us what year your car is
Old 11-16-2007, 05:32 PM
Re: Cabin Lights
Year
Make
Model
2003
FORD
TAURUS
Vehicle Type:
Passenger Vehicle
Year:
2003
Make:
FORD
Series:
TAURUS SES
Body Style:
Sedan 4 Door
Engine Vin Code:
U V6-182 3.0L OHV
Cylinders:
6
Displacement (CID):
182
Fuel:
Gas
Carburetion:
Fuel Injection
Weight (lbs.):
3,329
Wheel Base (in.):
108.5
Tire Size:
16R215
Base List Price (USD):
21,180
Air Conditioning:
Standard
Power Steering:
Standard
Power Brakes:
Standard
Power Windows:
Standard
Tilt Wheel:
Standard
Security System:
Pass Key
Front Wheel Drive:
Yes
4 Wheel Drive:
No
Anti-Lock Brakes:
4 Wheel Standard
Daytime Running Lights:
Optional
Standard Transmission:
4 Speed Automatic With Overdrive
Standard Radio:
AM/FM CD
Radio Opt 1:
AM/FM Cassette
Standard Roof:
Standard Roof
Roof Opt 1:
Power Sun/Moon Roof
Old 11-16-2007, 09:24 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Cabin Lights
You may want to try swapping out your accessory delay relay. This is the relay that normally will keep most of these electronics active for some time duration after the key is shut off or until a door is open.
You may also be experiencing the all too common stuck door ajar switch. Do you experience the same delay if the passenger door is opened and closed?
-Rod
