Old 11-16-2007, 06:51 AM
ctroll ctroll is offline
Unhappy 92 Astro Van - No Heat
I have a '92 Astro and just this morning (the first day of any significant cold and snow, of course) the blower runs fine, but no heat - only cool air.
I ran the van for about 15 min in the drive to warm it up and scrape, then an 8 mile stop-and-go trip to work - usually the defrost is blowing hot air before I get down the street when I do this. No hot air at all this morning.
Also, the water temp indicator looked normal - no overheating or anything. I ran the defrost earlier this week and it worked fine. So, it seems whatever happened - just happened.
Any suggestions where I should start looking this weekend? Heater core?
Any input would greatly be appreciated.
Thanks!
Old 11-16-2007, 09:14 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 92 Astro Van - No Heat
Low coolant level is the number one reason for no heat- make sure your radiator is full and the burp box has enough in it-- if you are truly low- then you need to find the leak- can be water pump or some other hose-- if no leak found- then pressure test radiator- you may be burning coolant internally......a much worse scenario...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 11-19-2007, 07:14 AM
Update...
This weekend I checked the fluid - a little low. I flushed the radiator and replaced the thermostat & filler er up. I now have heat, but it seems almost intermittent - it will be hot, then cool down, then get hot again - all while driving. Also, I started to notice a foul smell when the blower & heat is on. Kind of like eggs ???
I could not detect an obvious external leak as of yet.
Old 11-19-2007, 06:37 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Could be a blocked or leaking heater coil. the heater coil is inside the black plastic cover just above the front passengers feet. if you flushed the radiator I hope you hade the heater set to hot so that you flused the heater coil too.
