Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-16-2007, 12:19 AM
Robert Moller Robert Moller is offline
Please Help 95 rodeo fuel problems
95 rodeo, had trouble starting for a couple of weeks, parked one night the next morning, nothing..... would not start. motor turns over sounds like no fuel. I took the fuel line off and there is nothing. I replaced the fuel filter, nothing.. i replaced the fuel pump.....(that sucked) still no fuel... i checked the fuse under the hood next to the battery., its good.. i have read alot of these post and was wondering is ther a relay i should check????without spending much more money, anyone have any suggestions???
thanks for you time and help,
Robbie
Old 11-16-2007, 01:40 AM
pharm_rodeo's Avatar
pharm_rodeo pharm_rodeo is offline
Re: Please Help 95 rodeo fuel problems
Robbie
Have you checked your fuel pressure regulator? Prime the fuel pump before you start it up after its been sitting overnight. Turn the key to the on position short of starting the truck. Do that a couple of times. You should hear the pump. Then try starting it up. If that helps then I'd say your FPR is bad.
** The above is assuming that your battery and plugs are all good.**
1994 Acura Integra LS---212K+
1998 Isuzu Rodeo S 3.2L 2WD---176K+
Old 11-16-2007, 05:11 PM
FL 3.2L FL 3.2L is offline
I'm wondering about a fuel pump relay, too. Had this issue in my Jetta, but changed the relay before the pump!
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 11-16-2007, 05:54 PM
My Haynes mentions a relay for the fuel injection system, but I can't find where exactly it is or if it is in your specific truck. Anybody else???
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
