Old 11-15-2007, 08:34 PM
segrandam segrandam is offline
radiator
wondering how hard it is to fill a new radiator on
99 ga se v-6 do you just fill in the reservoir or
how do you do it?? had to replace the old one...
Old 11-15-2007, 09:55 PM
Blaze_316_316 Blaze_316_316 is offline
Send a message via MSN to Blaze_316_316 Send a message via Yahoo to Blaze_316_316
Re: radiator
What you think? lol ya its the res. it will drink it (Don't use pink antifreeze)(Gasket Muncher)
If its reused rad from wreaker use brakeclean and spray in tranny cooler line inputs on rad and chase out with air. might just save your tranny
200 Hp Quad 4 H.O. W41 Cams + Prom,
Rebuilt Motor
90 Cutlass Supreme International Quad 4 HO 5 SPD
91 Grand AM SE Quad 4 HO 5 SPD
92 Grand AM SE Quad 4 LO 3 Spd Auto
Old 11-15-2007, 10:34 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: radiator
You can also pour alot through the upper radiator hose to partialy fill the rad. Other wise it is timely to fill via the resivoir.
You will probly need to purge the cooling system.
Bleeder is on top of th ewater pump housing, brass fittings nortoriously prone to break off.
Might spray a little lube around the fittings threads.
it is a dealer part, but you can find simular fittings at a hardware that carries brass fittings.
1999 Grand Am SS 3.4 OHV
Old 11-16-2007, 12:48 AM
Re: radiator
thanks for the help guys guess ill be fine
tomm.do you purge it while its running??
im guessing you would or theres no pressure.
i`ll for sure clean the tranny line..just changed
tranny fluid and filter royal purple was exspensive
but worth it i think.thanks again
