Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-15-2007, 07:26 PM
cajun thunder cajun thunder is offline
Engine swap for 91 4WD
I have a 91 4wd V6 4 runner with 161k miles. The engine is feeling very weak, (0-60 in 35 sec) and it might be due for a rebuild/replace. I dont want to swap a 16 year old motor for another 16 year old motor, and I would not mind getting a little extra power since I am planning on lifting it an putting 33s under it. would a newer model Toyota V6 be a good swap? I am not worried about mpgs because it CANNOT get any worse than it is now, and it will be my mud toy not a daily driver. Any ideas would be great. Oh and one more thing, how much wheel offset would I need to run 12.5 in wide tires?
Old 11-15-2007, 11:20 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Engine swap for 91 4WD
The conversion to a 5VZ-FE (3.4 L) is fairly common. Here are a couple of links to kits
http://www.offroadsolutions.com/tech...n_kit_auto.htm
http://www.offroadsolutions.com/tech...ersion_kit.htm
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-16-2007, 08:39 PM
Wow I was not planning on spending 12 grand on a motor swap, I could completly rebuild the old block, install a TRD supercharger, and do my lift for half that much. Are there any ways to get a few more ponies out of the SOHC engine. I prob could do a rebuild for a grand, and port the heads, but would that be worth it?
