Go Back   Automotive Forums Car Chat > Pontiac > Grand AM > Tips and Maintenance
Tips and Maintenance Post helpful tips, maintenance guides and R&R procedures here
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-15-2007, 01:18 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Thumbs up 99+ Grand Am Front Hub / Bearing removal
1985 R&R coming soon...
Lug Nuts torqued to - 100 Ft Lbs(140 N-m)
Tighten the wheel nuts firmly in crisscross sequence as shown below.
The 99+ bearing/hubs are very simular to remove as the previous years listed above.
99 hub bearing-to-steering knuckle bolts-
torq 70 fT-lbs (94nm) also.
Hub & bearing assembly retaining bolts -
1999 - 70 fT-lbs (94nm)
2000 GA - 62 ft-lbs
*Driveaxle hub nut-
1997 30 ft lbs plus an additional 45 degree rotation.
**1998+ black nut torqued 284 fT-lbs - gray nuts torqued to 173 ft-lbs
*these need replaced with a new nut when removed.
** caution the '99-'04 Grand Am(and aleros) have two different axle nut torque values,
depending on which axle nut you have.
There's two nut designs.....
-The first design axle nut is a PAC type nut painted black and this torque value is the 284 ft-lbs.
-The second design axle nut is solid gray, torqued to 173 ft-lbs.
Hope this helps and If you have any questions
PM myself or post a thread.
1999 Grand Am SS 3.4 OHV
Closed Thread
