Old 11-15-2007, 10:56 AM
MOPARMAN01 MOPARMAN01 is offline
92 Noise in drivetrain
92 2wd v8 auto
has clunk noise when placed in reverse. The u-joints are fine. It sounds to me like it is in the rear of the transmission. The owner states that he has put a rearend in the truck one year ago because of it locking up. He thinks the rearend that is in it now is doing the same thing.
Any help on the noise and how to fix it would be appreciated.
Old 11-15-2007, 02:42 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 92 Noise in drivetrain
Check the transmission mount. Also check the freeplay in the driveshaft with the transmission in neutral and the parking brake on. There should be about 10-20 degrees of rotation. It's not a proper backlash test, but gives you a good idea if you need to pull the cover.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
