Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-15-2007, 09:26 AM
Gearhead406350 Gearhead406350 is offline
Send a message via AIM to Gearhead406350 Send a message via Yahoo to Gearhead406350
Crossmember
I have a 1991 Caprice Wagon and i am looking to finish off my dual exhaust. I recently bought a set of shorty headers and exhaust cutouts. What i was wondering was if there is a crossmember for my car or a car like it that has two humps in it for true dual exhaust. My car has a 700R4 trans in case it matters
1991 Caprice Wagon: 350 swap, dual exhaust, functional cowl induction hood. For now...
1985 Cutlass Supreme: Soon to get a 383, 4.11 posi, and strip off all the extra wieght
1969 Cadillac Deville: 472 big block, convertible
1929 International Pickup: Built from ground up, 6 in' dropped front axle, rat rod still in progress.
Old 11-15-2007, 10:26 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Crossmember
You can get the LT1 crossmember for a '94-'96 as it has two humps in it for true dual exhaust. You may or may not have to modify the driver side of your frame for it.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-21-2007, 03:09 PM
Siggi-Caprice Siggi-Caprice is offline
Re: Crossmember
I bought dual hump crossmember from Jegs for G-Body GM http://www.jegs.com/webapp/wcs/store...0002_347280_-1
It only needs to be a little longer, I welded about an inch at each end, no problem...
Siggi
From Iceland
Old 11-21-2007, 09:13 PM
ALLslowNOshow ALLslowNOshow is offline
Re: Crossmember
Try calling CIA, they have tubular crossmembers listed for your car that might work.
http://www.clearimageautomotive.com/...s%20member.htm
