Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-15-2007, 08:41 AM
1996EclipseRS 1996EclipseRS is offline
automatic transmission probelm.. =(
The gears shift nicely when not warmed up. The car will go 1 -- 2 and get stuck on 2 once the car is warmed up. Sometimes if i shut off the car and turn it back on it works again (shifts normal). Also sometimes if I keep it under 2k rpm while it shifts, it works... would switching to Pennzoil Synchromesh or BG Synchroshift help at all???
420A
JE Forged Pistons 10:5, Crane Super Street Performance Cams, Crower Connecting Rods, Crower Valve Springs, Port & Polished Head, A'PEXi SAFC II, DigiMoto Datalogger + more, Prothane Motor Mounts, Ebay Header =(, Stock Exhaust, busted driver side window, stolen SAFC(tear), blown tranny
-1984 Mercedes Turbo Diesel 300CD (270k)
-1992 Ford F-150 302 (180k)
Old 11-15-2007, 10:34 AM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Re: automatic transmission probelm.. =(
No, those are gear oils that are used in manual transmissions. You should use the right ATF that is specified for the car. Try checking your fluid. (Remember in park, vehicle running at operating temperature) Smell it and see if it seems burnt, if it is it should be something other than red. If thats the case, it might be time for a new filter and transmission flush.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
