Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-14-2007, 10:26 PM
camaroguy149 camaroguy149 is offline
97 camaro, issues starting, need help
ok, so i am confused here, i have a 97 camaro z28 . 10k miles on motor. it has 3 codes coming up. 02 sensor, secondary air injection malfuntion, and random misfire. So it turns over fine. it takes a few times cranking and it finally starts. not a few cranks, like crank, let up, crank almost starts, crank and starts with gas pedal a bit. ? so air injection? wat can be going on. i need help?
Old 11-15-2007, 02:47 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 97 camaro, issues starting, need help
call me crazy, but I think of you take care of the issues that are throwing the codes, the car will start and run like normal.
Old 11-15-2007, 03:15 PM
89BirdMan94 89BirdMan94 is offline
i kinda have the same problem with my 94 f-bird it takes a couple cranks then bam fires right up but the first couple cranks i get nothing the only similiar code i have coming up is the 02 sensor which i dont think is the problem so i also would like too know
Old 11-16-2007, 10:12 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
fauled plugs??
