Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-14-2007, 10:19 PM
tyler.winters tyler.winters is offline
butt sag of course
so i have a 95 4runner v6 4x4 and got butt sag. i have dont think the shocks have ever been replaced with 149,xxx miles. i got standard shocks to put on but would it give me a greater lift to get the rancho shocks that are compadable for 4runners with a 0-2 inch lift.
Old 11-14-2007, 10:55 PM
MikeRWK MikeRWK is offline
Re: butt sag of course
Shocks do nothing for lift, its the springs.
Current Project: 90 Mazda B2200 SWB
Old 12-07-2007, 10:11 AM
xthirdimpact xthirdimpact is offline
My explorer had that problem....that was 1 on a LONG list of many problems.
There are aftermarket parts/kits that are helped with that specific problem.
Here's a link to the site of the catalog for the parts:
http://www.performanceproducts4truck...es.aspx?cid=19
Old 12-07-2007, 03:09 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
If you wan't to fix your saggy butt, get better than stock ride and handling, and a small lift, all at once, check out the Old Man Emu suspensions. They really can't be beat.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 12-28-2007, 04:04 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Again, its the spring. They do sell spacers to put on top of the spring, to help even things out.
Old 01-12-2008, 11:58 PM
4Wheel's Avatar
4Wheel 4Wheel is offline
AF - Advisor
Most 4Runners have the droopy butt issue.
There is an easy fix, have an alignment shop drop the ride height on the front torsion adjustment, then have it ALIGNED after this adjustment as it will change the geometry of the alignment.
You can attempt this yourself but it will still NEED to be aligned. Start by soaking the adjustment threads with WD40 days in advance of the work.
If it has been in a salt environment (salted roads or coastal) there is a VERY good chance the bolt will shear! The torsion adjustment arm will then tear a hole in the floorboard, danger Will Robinson, danger!
What else needs to be aligned? You're right! The head lights!!!!
Old 01-24-2008, 06:28 PM
Kyle4130 Kyle4130 is offline
it would just be easier to lift the rear with some cheap spacers or get some new springs than deal with bolts that are basically welded to steering and torsion bars by salt/rust. that or cut it all off and put a solid axle under it!!!!
