Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-14-2007, 09:12 PM
wrightway dave wrightway dave is offline
93olds88 no dash lights
I have no dash lights at any time. With headlight switch on, or with daytime running lights on. When the DRL comes on, the radio and climate control displays dim so i can barely see them. With the DRL off the radio and climate display is bright (In the daylight). All fuses and relays are good and all interior lights work. Tried a new headlight switch and interior dimmer switch. I disconnected the DRL module but that didn't help. DRL module ?
Old 11-17-2007, 06:54 PM
back2life's Avatar
back2life back2life is offline
Re: 93olds88 no dash lights
there are little bulbs mounted into the back of the dash cluster. check them out!
Old 11-18-2007, 06:49 PM
Sorry. All new bulbs (194).
Old 12-14-2007, 02:56 PM
delta8811 delta8811 is offline
does the lights for the dash go out when you turn on the headlights and then come back on when the "P" switch is only on?
