Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-14-2007, 06:24 PM
boarder4life boarder4life is offline
Head
I have a 93 talon. i need a new head, and im havin a hard time finding one. all i want to really know is it the same head they use for turbo and non turbo? i found a 1 g head from a 90 laser non turbo, but i have a 93 tsi. would this head work for me? thanks.
Old 11-14-2007, 06:36 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Head
This does NOT go in the Tech Article Section...
Also, you don't need to make so many posts about needing a head...
Moved to Performance section to be discussed...
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 11-14-2007, 06:44 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Head
Any head from a 93-94 4g63 (turbo or non-turbo), or any 95-99 turbo head will work. The 90-92 head is a bit different. It will work, but you have to change a few things.
95 Talon TSI AWD
97 Eclipse GST
Old 11-14-2007, 07:12 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Head
Yeah, though I'm pretty sure all 4g63 heads WILL work, you are going to want to find one from 93-94 for the easiest swap.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-15-2007, 11:42 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Re: Head
Other than the electronics, the only difference between NT and turbo heads are the cams. But I agree with what is said, if you can't find one for a 93-94 you are going to have to do a little modification to make it work.
1991 GSX 2.3 Stroker
Old 11-15-2007, 07:46 PM
Re: Head
what kind of modifications would i have to make to it to use it?
Old 11-15-2007, 08:50 PM
Re: Head
I pulled this from vfaq.
All 1G 2.0L heads are the same except for the camshafts. Apparantly the 1990 heads had slightly smaller coolant passages, but the difference is not enough to be significant. Also, prepared non-turbo heads had a plug where the turbo oil feed would connect on turbo models.
95 Talon TSI AWD
97 Eclipse GST
Old 11-20-2007, 02:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Head
I'm not aware of any year based change in the 1g heads. A 2g head will be such a pain in the ass to put in a 1g I wouldn't bother (intake manifold and TB, front water pipe, tstat housing and water neck, etc). It's a backwards swap anyway unless it's heavily ported.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
