Old 11-14-2007, 04:08 PM
goad goad is offline
94 T/C Fuel Pump
I went to start my van and it will not start. Cranks but will not start. I can not smell fuel and I do not hear the fuel pump engage when I turn on the key.
SO....I am making an assumption that the fuel pump went.....
Does anyone know where I can get help with replacing the pump? Diagrams and instructions?
I have a 2wd 3.8l engine and again...assuming that the pump is in the fuel tank.
Any help would be greatly appreciated!!
Thanks
Ken
[email protected]
Old 11-14-2007, 06:27 PM
tempfixit tempfixit is offline
Re: 94 T/C Fuel Pump
No. 1 - Check all fuses to make sure fus is not blown for fuel pump.
No. 2- Check fuel pressure. Check this site for procedure: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Post pressure readings.
No. 3- Try hitting the bottom of fuel tank with rubber hammer, this may jar the fuel pump to where it may run again (If this does work the fuel pump will need to be replaced.)
No. 4- Procedure for fuel tank removal: http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Hope this helps
Old 11-14-2007, 08:59 PM
Thanks for your reply....I am unable to check the pressure. I just dont have the equipment to do so.
I had heard that some automakers out an inspection plate on the floor that when opened (6-8 screws) gives you access to the tank opening so that you will not have to drop the tank....do you know if the Chrysler has this?
Ken
Old 11-14-2007, 10:23 PM
sneakybert sneakybert is offline
Sorry , no such inspection plate on a Chrysler mini - van .You will have to drop the tank .
Old 11-14-2007, 11:14 PM
Hey thanks for the feedback................
Ken
Old 11-15-2007, 07:17 PM
Check with Autozone they may have a fuel pressure tester that you can rent. Have you checked the fuse for the fuel pump?
Have you tried tapping the gas tank to see if fuel pump runs?? even using a board to tap the fuel tank will work. Hate to see you replace parts that do not need to be replaced.
