Old 11-14-2007, 11:34 AM
blu3kgt blu3kgt is offline
Ground control adjustable coilover suspension kit
i was just wondering, is this like an alternative to actual coilovers???? so you just replace you stock springs with these springs and you will be able to adjust your height just like the expennsive coilovers???
http://www.3sx.com/store/comersus_vi...idProduct=1535
97 3kgt sohc.... intake, custom exhaust, 3sx crank pulley, JVC head unit, pioneer speakers all around for highs and mids amped, 12"JBL power series sub....
Old 11-14-2007, 11:46 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Ground control adjustable coilover suspension kit
It isn't quite that easy. You have to cut the spring perch off the strut to make them fit, but is essence, yes.
Old 11-14-2007, 12:01 PM
cool...because i want to lower my car but the eibach springs i think don't lower it enough and the tein coilovers are just way too expensive
Old 11-14-2007, 12:10 PM
Polygon's Avatar
The Red Baron
I would suggest a set of Koni Specials (Red) and the Ground Control kit. Just be careful when cutting the spring perches off.
Old 11-14-2007, 01:35 PM
alright thanx for the tip....one more question...do you think i will be able to lower it like to 2 inches or more....basically do you know what is the maximum i could lower these to??
Old 11-14-2007, 01:40 PM
Polygon's Avatar
The Red Baron
Ground Control would be able to tell you that, but I don't think you can go more than 2" without screwing up your camber.
Old 11-14-2007, 05:21 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I dont even think Koni makes struts for us.
In my opinion, I wouldnt waste the money on sleeve style "coilovers" Yes you can adjust the height, but thats it. It will blow your struts out at a much faster rate and you dont have the ability to adjust dampening.
And as for camber, I dropped about 2 inches and my rear camber was way out. I have aftermarket adjustable rear control arms, I just need to get it aligned.
Old 11-14-2007, 05:36 PM
Polygon's Avatar
The Red Baron
Really? You should be fine at 1" I would assume, if not, the rear arms are cheap. Also, unless Koni discontinued them they did.
Old 11-14-2007, 05:41 PM
Stealthee's Avatar
Koni has never made one for a 3s that I have ever seen. And Ive been in the scene for over 5 years now.
Old 11-14-2007, 05:59 PM
Polygon's Avatar
The Red Baron
By damn, you're right. I could have sworn I saw us in the catalog, guess not.
Old 11-14-2007, 06:45 PM
damn... stealthee has a very good point.... im screwed, i will just have to save up for coilovers
