Old 11-14-2007, 08:30 AM
4.3 liter hater 4.3 liter hater is offline
bogging out
when i give its gas it hesitates,dies out for second then kicks back in. I checked the sensor but no codes where given. dont know if it is just a bad ground or ignition problem. any ideas?
Old 11-14-2007, 08:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: bogging out
Welcome to AF.
What year and engine and mileage?
How is the tune up end?
Any engine miss?
Any check engine lights?
The more info you give us the more we can help.
MT
Have you checked fuel filter and fuel pressure?
MT
Old 11-14-2007, 08:11 PM
Sinful7 Sinful7 is offline
Re: bogging out
Check the fuel pressure, sounds like a bad fuel pump. :-(
Old 11-15-2007, 10:16 AM
Re: bogging out
93 gmc jimmy with the 4.3 vortec motor. i towed it home today. now will not start. I have a good spark to the destributer but alot weaker to the end of the wires. when i try starting you can smell a lil bit of fuel. i have good fuel preesure to the spyder injecter. oh yeah 223,000 miles on it.
Old 11-15-2007, 10:15 PM
Re: bogging out
How did you measure the spark intensity? Visually? Maybe a cap/rotor/wire problem, but in my experience, usually that won't prevent firing like weak fuel pressure will. The spider won't even activate with low pressure. I've replaced my pump twice in the last 5 years when the truck was acting as you described.
What is your pressure reading?
