Go Back   Automotive Forums Car Chat > Ford > Freestar
Old 11-14-2007, 08:22 AM
phil a phil a is offline
2004 code po705 transm.?
I have a check engine light on..
ReturnZONE" said po705 tranms sensor?
everything works well,,, any clues.
Thanks phil...
Old 11-14-2007, 11:48 AM
garync1 garync1 is offline
Re: 2004 code po705 transm.?
Good news is nothing wrong with the trans.. 705 is Transmission range sensor circuit PRNDL input. So if one day it does not start then the neutral safety part of range sensor has went out..In that case the range sensor will have to be replaced. So you may first check out the plug for the range sensor for damage or dirt and corrosion. Other than that I don't see in other issue for this code. Not unless you are having problems when you put it into one of PRNDL. Make sure wires are ok in that area..
