Old 11-13-2007, 10:50 PM
hk09 hk09 is offline
body color
I was think about spray my nissan fairlady z Version nismo with pearl white and I would use light grey primer for last coat. Do you think this will look good?
Old 11-13-2007, 10:51 PM
blubaja's Avatar
blubaja blubaja is offline
Re: body color
Why don't you just use white primer? Or if you use the grey primer, and a white base color...shouldn't be bad.
Old 11-13-2007, 11:01 PM
Re: body color
i have never try to use primer, so i don't know if it would good or not...
Is there any clear primer?
Old 11-14-2007, 12:14 AM
KyMDLR's Avatar
KyMDLR KyMDLR is offline
Re: body color
I think what you are saying is you will use gray primer on the body, then cover it with pearl white? I would say use gray primer as the base coat, followed by WHITE primer, then you can spray the pearl white over it. Spraying white top coat over grey primer will distort the top coat color.
Old 11-14-2007, 12:51 AM
Re: body color
I am new to primer. Is the the primer suppose to be last coat of the paint?
Start:gray primer-->white primer-->pearl whiteTS-45. ??
Old 11-14-2007, 02:14 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: body color
no
First primer, then paint.
Yes this is the right way.
Primer is applied to prepare for paint.
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 11-14-2007, 10:26 AM
Re: body color
What paint do I need to use to make the paint shinny and smooth?
Old 11-14-2007, 11:32 AM
freakray freakray is offline
AF Modelrater
Re: body color
Clear coat.
I strongly suggest you read the questions in the FAQ (http://www.automotiveforums.com/vbul...ad.php?t=63623).
There's a great deal of info there which will hopefully help you get off to a healthy start
AF User Guidelines
Old 11-14-2007, 01:41 PM
Re: body color
so, I would also need to get Spray Lacquer TS13 Clear to make the body smooth?
Old 11-14-2007, 05:18 PM
Zurbert82's Avatar
Zurbert82 Zurbert82 is offline
Re: body color
Any paint can be made smooth with sanding and polishing. Like freakray said, check out the FAQ's.
